i have a worcester bosch junior 24i combi boiler fitted with a honeywell DU145 automatic by-pass valve. What i wish to know is when is the boiler operating most efficiently? I believe that this occurs when the differential central heating water is above 20degC, ie the difference between the feed and return temps. I have taken temp measurements on my system and I only see a maximum difference of 15degC (see attached plot). Is this what I should expect or should the differential temp be higher and for a longer period?
How do I know that the by-pass valve is set up correctly, as it seems to allow hot feed water seep through the valve at all time, ie when all the TRV are fully open (the radiator in the hallway has no TRV)!
