- Joined
- 27 Jan 2008
- Messages
- 29,214
- Reaction score
- 3,582
- Location
- Country
I do not want to pinch some one else post and so have started this.
With the post "table lamp fault" there was a
link which talks about the non-contact voltage detectors.
In that write up from fluke they refer to testing before and after the test and I am sure we have all used proper proving units with the testers similar to this
with something like this
but these testers and proving units have a hard wired connection and do not require any ground or aerial to work.
With the volt sticks we would rub them on our jumpers to see if battery is OK but this could hardly be considered as a proving unit.
Although as a safety item the use of volt sticks and neon screwdrivers may serve as a second string to warn I would never consider no light from either to be proving dead.
However this
I had my 12vdc to 230vac 150W inverter strapped to a lead acid battery about 3Ah that I used as a proving unit and that does not light a volt stick.
There is a warning about voltage and different units being sensitive to different levels and this has been talked about before. Should the proving unit be able to deliver a range of voltages so we can both prove the 500vac lamp works and also more important the 50vac lamp will light at 50vac?
Love to hear what others think.
See
for example of what I mean all voltages tested not just 500v.
However this
makes one question their use, in the main what is required to "verify that the voltage detector is working properly" as I would not expect any proving unit since a isolated supply will light a volt stick?1. Always verify that the voltage detector is working properly before you rely on it. Use the detector to test a known live circuit both before and after you test an unknown circuit, and make sure it gives you the proper response. The same practice applies to multimeters. If there is any doubt in your mind about whether the circuit is truly live or dead, use an additional method to verify the test results. You only have to be right once to make it all worthwhile.
Note: Some voltage detectors, such as the updated Fluke 1AC II, have a self-test function built-in that will verify whether the detector is operational.
See
