draining boiler
19 Dec 2010
Cheshire
Hello everybody,
I live in a bungalow on my own, and I work abroad quite a lot, usually for about 4-6 weeks alternately away then home.
Whenever Ive been before, I have allways closed the stop tap inside, as you would.
I want to go a step further next time, (mid january) and completely drain the system, there are drain taps on all rads, so nearly all the system can be dr ained easily, but....how do I drain the boiler, if flow/return go up into the loft, then drop down to rads, (no pipes going down from boiler).
Boiler is a Glow Worm 24hxi.
Ther is what looks like a small drain screw on the flow pipe behind the inner casing,but is called a vent screw in the book, can I use this to drain?
Thanks.
Not a particularly clever thing to do, as you will either have to add inhibitor every time you fill it back up, or have the system rot away.
Your idea is unnecessary. Heating system should only be drained if house is to be left indefinately, eg. When empty long term (unfurnished) awaiting sale, tennants or re-furb. Even though you're away your home is still classed as inhabited and should be maintained as such.
Thanks for your advice lads.
but every time I switch on after a long lay off(about 4-6 weeks), the red warning light flashes and boiler wont fire.
Until I press the reset switch on the flow pipe,
cheers
cheers
And?
I suppose the answer then is to leave alone ,dont drain the system.
thanks.
p.s. I think the glow worm hxi is a good boiler, had the space saver 45-60
in previous property, would love to know what you guys,..the proffesionals
think?.
i
