N
NotSoFast
I have a Potterson Suprima 60. It is 12 years old and has the original PCB. It was last serviced about 6 months ago and is attached to a Boilermate II. I had a couple of issues with the Boilermate (mixer valve failed, delay timer PCB fried) which I've fixed. The Boilermate is now working as designed which has highlighted a bit of a problem with the boiler.
The Boilermate makes a call for heat. The boiler responds until at some point it shuts down. On shutdown it will revert to displaying Ext. Call for Heat (Green LED flashing, Red LED off). After a time this changes to Boiler Temp Control Satisfied (Green LED flashing, Red LED on). Meanwhile the Boilermate continues to call for heat (checked with a voltmeter) as the Boilermate boiler pump circulates increasingly cooler water.
If left to its own devices the Boiler seems to re-fire when the water in the pipes drops to around 50c (yep, I've spent a lot of time hanging round the boiler waiting for things to happen
). If the Boiler is switched off/on at the mains it will fire immediately for some indeterminate period (often as little as 30 seconds, sometimes more than 5 minutes).
I've read lots of threads on here but can't find these exact symptoms. Its not a lockout (green LED off, red flashing manically) but is it more likely to be a faulty thermistor/thermostat or is the PCB on its way out?
