I've finally have a new condensing boiler fitted and all it working well.
Tiding up the area in preparation for fitting a cupboard round the boiler I noticed that where the flu and drain go through the wall the gap between the brick and the pipe haven't been filled ... just a rubber flange pushed round it. This doesn't seal great (at night you can feel a slight draft round it). The plumber has gone on holiday for a couple of weeks so I thought I'd ask here ...
1) Can I fill the gap with standard mortar?
2) Should the flu be angled slightly downwards as it crosses the cavity wall? Anything else that does is supposed to (or have low points in the middle) in order to make sure and dampness runs to the outside wall and not the inside wall.
