Everything above 2.25m is outside the Zones as defined in the 17th Edition.
The Building Regulations concerning notifiability still refer to the 16th Edition, and above 2.25m might be outside the Zones, or you might need to be above 3m.
See http://www.diynot.com/wiki/electric...zones-in-relation-to-notifiable-work.[/QUOTE]
So what, I will still use the 17th edition and I will not be in breach of the Building Regulations.
You will be if you fail to notify work which is outside of the 17th Zones but in one of the 16th ones.
No - the latest amendment changed that so they now refer to the 17th Edition Zones.
And since the Wiki is a collective responsibility, he could have edited that, too.
BAS how come it is my fault that you got it wrong - A simple 'hands up' I got it wrong would have done - end of story. Or are we now working to the rule:And since the Wiki is a collective responsibility, he could have edited that, too.Everything above 2.25m is outside the Zones as defined in the 17th Edition.
Rule 1: BAS is always right.
Rule 2: When BAS is wrong rule 1 applies.
I hope not!
It's not.BAS how come it is my fault that you got it wrong
No I wont - where does it say that?
A simple "No - the latest amendment changed that so they now refer to the 17th Edition Zones" in reply to this would have done - end of story.A simple 'hands up' I got it wrong would have done - end of story.
1) Show me where I'm claiming that I wasn't wrong, or denying that I was.So I guess rule 2 applies then.![]()
2) When you've failed to do that, try growing up instead.
Are you hard of thinking?So I guess rule 2 still applies then.
If you didn't know that then you would have believed that the law still referred to the 16th, so why on earth did you write:You assumed that I knew that the latest amendments had changed the reference to the 17th edition - I didn't - so you were wrong there.
?Everything above 2.25m is outside the Zones as defined in the 17th Edition.
If you didn't know that there had been amendments changing the definition of "special location" to reflect the changed Zones in the 17th, why did you write:
Unfortunately it took the law over 2 years to catch up. Now - you can rail against that as much as you like, and pour as much scorn and derision on the heads of the civil servants responsible as you like, but it would do you as much good as howling at the moon - it would not change the fact that until 1st October 2010 the definition on law of "special location" referred to the definitions in the 16th edition.As soon as the 17th edition of BS7671 came out I immediately ignored everything in the 16th edition - it had no relevance to me it was a dead document - nice for historical reference - but of little use.
And you would unquestionably have been wrong.So if this had come up twelve months ago I would still have said applying the 17th edition to Part P would not have broken the law.
At the time I made it I did not know that.As for your ridiculous statement that I would liable if I failed to notify work outside the 17th zones but in one of the 16th zones is arrant nonsence and you know it.
You were also unaware of the change, but you made assertions based on it - i.e. you made claims which you believed were nonsense.
You did not know that the law no longer referred to the 16th, yet you said "So what, I will still use the 17th edition and I will not be in breach of the Building Regulations.", so you should probably be wary about passing judgements like "arrant nonsense".
It's all rather academic. The work is notifiable because it involves 12V lighting.
