hi all im having a problem getting my boiler to light for the water and radiators to work , ive tryed resetting, insulating outside piping (yet its not really that cold)
boiler will turn on fan will run , pcb board will click a few times then cut off shows a fault of e133 gas supply fault , as ive read a few people saying its the flue/frozern pipes or a pcb hose that gets trapped when these boilers are serviced?im unsure tbh , everything works other then the gas light dosent show on the boiler , ive also checked the water pressure witch is nicely in the green, tryed resetting with no joy , , so i thought i carnt cope with no heat , so called a gas engineer out who said its problery ur fan on its way out????(2year old boiler shocking) yet i can hear the fan partly working well , bit as it seems not to light the fan will stop ,also we never really had any problems until the alterd some copper piping and a flue externtion was fitted ,(due to outside work) but the gas man says its nothing wrong or to do with the gas fault u have , , so nearly a week later still a no gas working and been told we now how to wait another dam week ,, with no heating, if any of u guys have any possible ideas i can try , im greatfull to give it a go , and report back,
