Ok so given that the screed is not perfectly level and varies in height from the lowest to highest point but 2-3mm will it be ok to lay the wood floor straight on the screed
I thought that a screeded floor was a 50-75mm of screed (4-1 floor mix) put on to the concrete slab and finished to the level of any existing floor level and existing openings so carpets and floor coverings could all be bought through level.
That was me & I’d still lay the screed BEFORE plastering, especially when dry lining.It has been said in other posts of mine that this was the wrong way round but i had already had the plasterer in.
That was me as well.I was told to chop back any excessive plaster off so that the plaster stopped about 12mm above the final floor level before the screed was laid.
You need the gap all the way around or water will wick into the plasterboard. With modern DPC/DPM there is far less chance of plaster wicking damp from the screed but it’s still a good idea to leave the gap on solid floors as it’s also a benefit if you ever flood the floor (it happens) as the water will wick up quiet a distance & if plasterboard is left damp for any length of time, it will disintegrate; lets hope yours doesn't.This i did but i didnt remove the excess of the plasterboard around the cheeks of the patio doors and also around entrance to the extension
Unfortunately at these points the plasterboard has got wet at the bottom (about 2 inches high)
Ah, but it will weigh a good bit more when he puts his fish in it. (Or will it?)My maths a bit out - (1 litre water = 1kg plus all the rest - as well as external filters being full of water) but never mind.
It will unless you remove the displaced water - think Archimedes looked into this in his bathAh, but it will weigh a good bit more when he puts his fish in it. (Or will it?)My maths a bit out - (1 litre water = 1kg plus all the rest - as well as external filters being full of water) but never mind.
