cooker cable sizes
6 Jun 2010
Devon
Need to wire for 2 cookers and a 20 amp rated hob over a distance of 20 metres wondering what cable sizes are required,I was thinking about running a 6mm for the hob and a 10mm for the two ovens,has anyone got other ideas,Thanks
Then you should be quite capable of performing the calculations and referring to the regs for yourself.
NO NEED TO GET ARSEY MATE ONLY ASKING FOR OTHER SPARKIES IDEAS,GAVE UP SEVEN YEARS AGO,NO DOUBT REGS HAVE NOW CHANGED
Do you remember your power triangle and your diversity factor?
I should have thought as an ex-electrician you would have told us power ratings in kW. And also I would have expected you to have considered running three separate cables, one to each appliance - though this may not necessarily be cost effective.
