External Sounder on floodlight Pir
15 May 2009
West Midlands
I am installing a floodlight in my garden and wondering, if I could also attach some sort of sound with it. So every time light comes on due to movement in the garden, a sound (Alarm) starts as a deterrent. IS there such a thing available?
Am I being too extreme here?
I think that is extreme,
everytime a cat or fox goes through your garden an alarm will go off
your neighbours will love you
agreed, it could be a problem however if your still interested in doing the siren thing what you do is run another cable back in the house from pir-lamp, you connect the earth and netural to the correct terminals however you connent the live retun feed on the lamp switch terminal, usually white. the other end of the cable in the house/shed/garage etc wire up a mains socket and then plug in a 12 volt power supply then run a 12 volt siren off that. this allows you to turn the siren off if there was ever a problem as you can unplug it too
Or much better, replace what you have with sighting system that is designed to do exactly what you are looking for.
There are ones that will sound inside or out, or both
By the way, forget the cat / fox scenario, if set-up correctly there should not be too much of a problem.
Thanks. Can you give me a link for the product? I can't seem to find anything.
