Hi all,
As part of my cellar conversion, my consumer unit is being moved about 2m along a wall. This means extending a number of cables. (Some can be taken back to their nearest port-of-call, but several cannot without much hassle.)
Wall will be plaster-boarded (currently it's mostly brick).
Junction boxes must be accessible, I believe.
My proposal is to put an access panel in the wall roughly where the old consumer unit was...
http://beta.screwfix.com/p/access-panel-250-x-200mm/20924
...and behind that have the required junctions.
Question is: how to make the junctions.
About 10 cables (mostly 2.5mm twin&earth) need to be joined and the 30A JBs needed are much too large to fit 10 of behind a panel like that.
Can anyone recommend a more compact way of doing it? Terminal blocks would fit, but would that be OK, just covered by the access panel?
Thanks!
-Mark
Thanks!
-Mark
