Thanks for you help guys.
Hi Ben,
the order numbers are also different. See items 131 & 135 from the image attached.
Hi Josh,
if it was an ignition fault, why does the DHW work ok?
If the temp sensor was faulty (i.e. measuring higher temp than the real temp), the boiler would stop & wait for 3min before restarting again. The issue I have is that it ignites on /off every 10sec or so.
Hi Ben,
Hi Josh,
