I've just moved into a flat with a Vaillant ecoTEC pro combination boiler.
I was astonished to learn that the system has no room thermostat, however apparently the radiators all have "thermostatic radiator
valves".
Additionally the boiler has a knob called the "maximum radiator temperature control" that makes the overall system run hotter or cooler. I control it by raising or lowering that.
I have 3 concerns:
1. some parts of the flat are real warm, and some are real cold. How difficult is it to adjust these radiator valves individually to get more even heating? Any tips about doing that?
2. is this a sensible setup? Seems slightly mad to me. Without an actual room thermostat, how does the central heating know when to ignight?
3. I notice in the installation guide that it seems easy enough to add a room thermostat. Should I? What's the gain? For example: Am I wasting energy by not having a proper thermostat?
The boiler installation guide is available http://www.vaillant.co.uk/stepone2/data/downloads/d7/42/00/ecotec-installation-and-servicing.pdf
The boiler user manual is available here http://www.vaillant.co.uk/stepone2/data/downloads/19/43/00/838402_06.pdf
Thanks for any thoughts!
Geoff
valves".
I have 3 concerns:
Geoff
