Hi all,
I have an old Vokera Eclipse combi boiler and it has gradually been getting noisier (rumbling bubbling noise) and the hot water has been gradually getting less hot...... it takes forever to run a tepid bath.
After reading around the web it seems fairly obvious (please feel free to correct me) that my heat exchanger is scaled up to the point where it really needs a good descale. The water is moderately hard in my area and I am guessing the previous owner never did this..... and I have lived in the house for 5 years now.
The heating is generally rubbish as well.
I have seen that there are a number of approaches to descaling the Heat exchanger, and I think that probably my favoured approach is to remove the heat exchanger, attach some pipes either side, attach a drill powered pump, and then run a very acidic solution through it until it cleans up......
Do any of you have any thoughts on this and whether there is a better way?
I dont know how hard it is to remove the heat exchanger yet....... this may also be something that someone else can help me with!
Thanks for any help/advice you can give.
Regards,
Ben
Regards,
Ben
