Hi All,
I am looking at replacing my existing hot water cylinder and considering the various options. I think I understand the options - but no idea on the best solution!
I currently have a Worcester Bosch Greenstar boiler (30CDi I think from memory) - just fitted last year - fully pumped, with open vented cylinder right above the boiler. The primary circuit is also open vented if that makes a difference.
The house will (eventually) be a 1 bath / 2 shower / 4 bed property.
Existing cylinder is too small (100L?) and takes an age to re-heat and has no immersion. Lots of renovations, so trying to do the major tasks first.
Option 1 - vented copper cylinder
Option 2 - vented stainless cylinder
Option 3 - unvented stainless cylinder.
Option 1 is fine - like for like - cheap fix. I have read some posts about which cylinder - all seem pretty much the same from what I gather so just need to check the re-heat times if possible.
Option 2 - tempted by the flashy look to be honest (sad aren't I?), plus the supposedly longer life.
Option 3 - Never dealt with these - I understand it would give mains pressure hot water and remove the need for the header tank. Currently there is a HUGE difference in pressure between cold mains and hot and there is no chance of raising the loft tank. Removal of loft tank is appealing as the loft is a nightmare. My concern would be - are there any risks with this approach?
So - can anyone tell me what they would suggest, and with the option which cylinders I should consider? I don't want to waste money per se - but would rather do the right thing and pay the extra. The budget got blown by the architect anyway...
Thanks,
David.
Thanks,
David.
