- Joined
- 18 Mar 2008
- Messages
- 1,492
- Reaction score
- 1,098
- Country
I hear you Micky
you need to use the cylinder sensor. said it before, will prob have to say it again before it sinks in
OK, so the possibility of the link being missing was suggested by several contributors. But the men at the coal-face completely overlooked what should have been checked if they had gone about their job in a logical way.What's the betting that it turns out to be something very simple, which everyone has overlooked?
I'm still with UPGRADEME on this one
Does anyone know if this applies to this G-W model? If thats the case then someone has removed it for some reason!
Not about the link being missing, which you were the first to mention, but about the possibility of "test mode" ignoring the missing link.DH suggested I was barking up the wrong tree
D_Hailsham said:However I do think UpgradeME is barking up the wrong tree as the OP appears to have only used test mode as a test, the problem occurs in normal mode.UpgradeME said:Not even in test mode? - It looks like the OP has been running boiler test modes which may over-ride some 'normal' functionality!?D_Hailsham said:1. If there was no link between L and R on the boiler, it would not run at all.
