I have just finished plastering a bedroom and have decided to keep the plaster walls as they are (ie unpainted). I will need to seal the walls, but unsure of what product to use.
I would normally use water down emulsion, but as i am leaving the plaster exposed I am unsure what to do.
I would like the surface to have a slight sheen.
I came across a forum that mentioned using linseed oil. Do you think this would be a good idea. Is linseed oil not flammable and rather smelly?
Would a very water downed solution of pva to water be ok?
Any advice would be much appreciated.
Thanks,
Neville
Thanks,
Neville
