standard sized doorway in load-bearing wall
2 Jan 2008
Sussex
Hi
I am looking to move the doorway into our kitchen to allow us to make better use of space for kitchen units etc.
The doorway will be 'standard' sized in a load-bearing wall. I am only in the planning stage at the moment and need to move a radiator along the wall first (as it currently sits where the new doorway will be) as well as wrap up a few other jobs elsewhere in the house, so any advice would be much appreciated.
I intend to use some wall supports, such as these, http://www.hss.com/index.php?g=50049 to hold things up whilst i knock out the necessary brickwork for a boxed lintel, before opening up the doorway beneath.
Questions:
Are the wall supports adequate?
Is a boxed lintel appropriate?
For a standard width doorway, how large of a lintel do i need to be looking at?
For that matter, how large of an opening do i need to be making beneath the lintel?
How do you go about making good the floor in the new doorway?
Do i need to advise the local Building Control? If so, do they actually need to inspect or do i just submit plans/info etc?
I am a competent DIY-er, but have not undertaken anything as 'structural' as this before. Given that it is only a small opening (rather than removing a whole wall) I am confident that it is within my capability. Would anyone advise against and suggest otherwise?
Sorry, lots of questions. Any and all advice appreciated.
alp
Yes, but for a standard doorway you may not need to use any. It will depend how close the existing opening will be to the new one - i.e. if it is so close that both openings will be one large one before t'uther gets bricked up.
A precast concrete lintel (70mm x 100mm) will normally suffice for a standard door opening unless there are some unusual loads above the opening.
A p.c.c. lintel will sit within a metric course of bricks. Allow for 150mm end bearings.
Dig out the sub-dpc bricks, lay polythene dpm in the trough then fill with concrete or floor screed.
I personally would not bother. I would however take some photos of the lintel bearings etc before plastering over and keep them for future reference.
Thanks Noseall, much appreciated
The new doorway will be approx 2 metres away from the existing opening (on a wall of approx 3.5 metres total length)
What would you consider unusal loads? The wall on the upstairs floor is brick also and supports ceiling/roof joists.
The idea of taking photos along the way is a good one, thanks. Are you commenting from experience in undertaking this work for yourself/others.
Can anyone else share their view on the last point?
Cheers
alp
Hmm, quoting the previous message with your comments and then adding mine didnt really work as i expected. My comments are beneath the replies to the original questions.
