New Alarm Install
14 May 2009
Dundee
I am moving house in a month, and would like to install an Alarm system. I am happy to install myself, and am a techie type chap, loves gadgets and all that.
So it is a 3 bed house, I would like some recommendation on kit, there is a lot of choice out there.
Hard wired System.
PIR in every room X7
3 X Door Contacts
5 X Window contacts
I am looking for a system that uses a fob to arm and disarm, would be great if a 2nd fob can be used to part arm too at night.
Being a computer geek, I have looked at alarms with IP interface for config and remote monitoring, that would also be great.
Budget is fairly flexible.
Anyone got any thoughts?
Cheers,
Will
premier 48 as you can fit ip comm and ricohet radio equipment and program via laptop with wintex
Cool I came across this while looking, looks pretty much perfect, and the expansion options look sweet as.
How do the fobs work with this system, I cant seem to find the info on these.
Thanks for the pointer.
Will
I see you have put that you want it hard wired. is there a particular reason for this? Its much easier to fit a wireless system. The AEI SG4000 is a great system. It comes with 2x PIRs, 1x door/window sensor a remote control and auto dial control panel. Plus you can add any number of additional sensors to this system so that you can secure all your rooms. You can even add smoke detectors to this system!
Yeah, I dont want to think about batteries, also I will be gutting the house to install central heating, so running in wires out of sight will not be an issue for me, they will not be seen, and I just like the idea of real wires, hehe.
for wired, I agree with the others, premier 24 with an odyssey series bell, just pick your favourite shape, my favourite's the odyssey 3.
for wireless you would be looking at the *COUGH* Yale 6400
Thank you very much.
For door contacts, will any standard mag contact work with this system, I have found a nice panel, PIRs and Window sensors.
Cheers,
Will
hi just put your fob to the keypad to fullset and fob and part button to part set. you can set keypads to quick so you dont have to use fob just press part key. the 48 is the better panel as there are more add on options.
Risco and Scanny to name but two
and those for larger sums of money.
I am not particularly a yale fan, but the yale would be good for a person who wanted to have the challenge of programming a wireless system[/quote]
It's academic anyway but based on the original post, i'd say 'cheap' wasn't a deciding factor
my two pennies worth,
if you wanted to you could also get hold of a Galaxy control panel, touch screen keypad,
LAN module, RSS sofware, RF portal and fit loads of wireless sensors as well as wired one.
but thats just a thought>
the Risco stuff is good so is the Texacom 48 both will do what you want without much trouble, (and you get an engineers book with them, but you don't with Galaxy)
Oasis
steer away from DIY wireless kit, (we wont fit any DIY alarms as they are non compliant, but as a DIYer you can fit what you want were you want)
Thank you sounds just what I need :)
