earth bonding
23 May 2006
Oxfordshire
i recently replaced my s s kitchen sink. the old one had an earth bonding tag and was bonded to hot and cold pipes. the new one had no tag. how important is it to earth bond it ?
There is no longer a requirement to supplementary bond a metallic kitchen sink in a domestic situation
Consider accidently dropping a double insulated hand tool into the sink when full of water.
If the sink is bonded then there will be a path from the saturated electrics in the tool to earth via the bond. This will trip the RCD (if fitted) and remove power reducing the risk of electric shock,
If the sink is not bonded and the tap to sink "connection" is poor or the taps and not fitted in the sink then the saturated electrics will not have any path to earth so the RCD will not operate. The water will be pulled to a potential approximately mid way between live (230 volt ) and neutral ( about 0 volt ).
So without a bond the water in the sink will be at about 115 volts. Enough to provide serious shock if one is touching an earthed object and the sink.
The RCB will (should) trip on the current flowing through the body before the shock itself is fatal.
So do you mean I need to now throw my plastic washing up bowl away as that is an insulator?
If people are stupid enough to use mains appliances over a sink then that is their look out.
I have a lot of sympathy with that viewpoint, but the fact is that we live in a world (which some call a 'nanny state') in which many of our practices (and, increasingly, regulations) exist to reduce potential hazards due to situations and behaviours which are far less probable and/or far more stupid than that.
Kind Regards, John.
Get a sticker saying
"Do not drop power tools in the sink when full of water",
that ought to solve it.
What would you recommend I chian the wife to if I get rid of the sink?
