how bout one that cant bend his elbow matehahaha
its just a matter of practice hold the twitcher at an angle and run it down the walls add a little plaster to the tip of the nose this will help it run smoothly and fill out any hollows in the angle, but if you dont get good results with it dont give up keep plugging away with it practice makes perfect being able to use a twitcher will enable you to do small rooms or hallways in one hit, it took me a while to get the hang of it, i have a vid of me using one done a few years ago but some people on here dont like seeing vids or pics so i wont show it,After googling the name I discovered I actually bought a couple of these in a pack (only very cheap ones) a while ago. Will dig them out lol.
Are they called a 'twitcher' for any reason? Is it the action you have to do or something?
Is there a special way to use these or is it just a thing or going up and down the corners with it?
Any tips welcomed
Also I've noticed they do adjustable agled ones - are these better?
Might end up buying a decent on e you see if these cheap ones are pants.
Ta.
dont think that thinner coat is better its not, also i once heard the term one coating called bumping,"CHEATING" all you have done by doing one coat is cheated yourself out of a 2 coat thickness, also well done for giving the twitcher a go have another try tomorrow if it dont work use your brush, but try the twitcher first on every angle you do after you have done so many the knack will just come to you it wont take longPut it on thinner this time and the difference shows. Only did one coat this time as the first coat came off so well and didn't want to ruin it.
One mistake I did was I had a bit of mix left over so did a small side wall - I know I shouldn't do adjacent ones but thought I'd give it a go.
Eventually got it ok, but needed a really steady hand to tidy up the joining edges.
Tried the 'twitcher' - Hadn't read your advice on this so just dragged it down the corner - Pulling off some of the plaster
I quickly put it down, but not I know the technique, will try again tomorrow.
i never meant your twitching all i meant to say and express was that any spread who cant use a twitcher is cr@p , and i meant i would rather be a spread with a bad arm than somone who has never been able to use one, and your right you do get better corners twitching than doing opposite wallsnothing wrong with my twitching
i never meant your twitching all i meant to say and express was that any spread who cant use a twitcher is cr@p , and i meant i would rather be a spread with a bad arm than somone who has never been able to use one, and your right you do get better corners twitching than doing opposite wallsnothing wrong with my twitching![]()
