Bathroom extractor
24 Oct 2005
London
Our bathroom extractor fan died. Looks like a be snarled one of the blades (wouldn't turn till I fished it out) and it may have burnt out the motor.
Anyway, I am changing the unit and I cant work out the (simple) wiring. The unit I am putting in is the model up with a timer. The old one had 2 terminals and this one has 3 (L, L1 and N) and 4 wires coming into it 2 browns and 2 blues. It is double insulated so no earth.
I checked the wires and they are as follows.
Brown - constant live not switched.
Brown - Nothing
Blue - Nothing, but when browns are together it is switched
Blue - Nothing.
How do I wire it up?
Usually L - Permanent (constant) live
L1 - Switched live
N - Neutral
Cover the CPCs (earths) with green&yellow sleeve an place out of the way. Do not cut them.
Brown - Nothing
Blue - Nothing.
Do you mean the first Blue is live when the Browns are connected? If so, does it not switch off and on with the light switch?
L1 - Switched live
N - Neutral
Brown - Nothing
Blue - Nothing.
Sorted. It does have it's own switch.
Both browns to L. One blue to N and the other to L1.
Thanks anyway.
Ok. Blue to L1 should be sleeved with Brown or marked with brown tape to indicate its use as live conductor.
