Would depend on the structure and size of the decking and layout. Not something you included.It has to be very secure as it is supporting decking. What would you use ?
Threaded bar and resin anchor
http://www.screwfix.com/search.do;j...T4gP6JH2V5dZSLQNG!-1515340339?fh_search=resin
http://www.screwfix.com/p/a4-stainless-steel-threaded-rod-m20-x-300mm-pack-of-5/49064[/QUOTE]
I appreciate the suggestion but this is 4" x 2" which is essentially around 50mm thick. Forgive me if I have missed something but just what would I do with something 260mm to 300mm long ?
Why did you use Celcon blocks instead of concrete?
Would depend on the structure and size of the decking and layout. Not something you included.It has to be very secure as it is supporting decking. What would you use ?![]()
Alligator solid wall anchors, they expand along the drilled hole and will hold more securely than chemical or mechanical anchors of the same size.
Read more: http://www.diynot.com/forums/viewtopic.php?t=277530&highlight=#ixzz1OR0XZ56Y
You could use either bolts or screws, use the 8mm or 10mm, they fill the drilled hole so have 100% contact. If you go into a cavity, they pop open and wedge in the cavity.Alligator solid wall anchors, they expand along the drilled hole and will hold more securely than chemical or mechanical anchors of the same size.
These seem great but what size and what to screw into them ?
Cut them down to size and then use washers and nuts to hold to the wall, you said it had to be secure, with that it will be.
