Light Wiring Problem
11 Jan 2010
Leeds
Hi all,
I've had my upstairs bedrooms reborded and skimmed. Now the ceiling lights in 2 of the rooms have the normal lve, netral and earth but the third room has the following:
3 black wires
3 red wires
1 gray (black inside)
1 green
It seems to me that this room completes a parallel circuit. Problem is how do I rewire the ceiling fixture? I gues one of the black and one of the red wires goes in to the loop section but how do i know which ones?
Thanks,
Daniel
Ok checked the switch and there are the normal 3 wires 1. live 2. netural 3. earth
Shall I get an electrician in?
3 black wires
3 red wires
1 green
It would be a good idea to get an electrician.
Meanwhile -
What does "1 grey (black inside)" mean?
1 green - is this three wires inside one piece of green&yellow sleeving?
I presume the green is the earth but no it isn't green and yellow.
The grey wire has a double coatsing so insulated firstly in black casing and then over that grey casing. Obviously some parellel circuit going on but I think it's best to call my electrician frind in!
Ps. Don't want to sound rude but putting; Probably not and no it isn't, is no help to anyone.
Au contraire - I was merely pointing out that it is extremely unlikely that "one of the black and one of the red wires goes in to the loop section" with the implication that you should not try it.
Turn off the power.
Ignore the Grey for the time being. Safely cover the end and put out of the way. It's impossible to say what this may be from here.
Normally -
Connect all 3 reds together in the loop section, i.e. the centre portion of the ceiling rose.
One of the blacks will be the switched live returning from the switch. You will have to determine this by testing. Sleeve it with red and connect to the live connection of the rose.
The other two blacks go to the Neutral connection.
There should be a bare CPC (earth) from each of the cables. Sleeve them with green&yellow and connect to earth connection.
The live wire from the lamp (brown or red) will connect to the red sleeved black and
the neutral wire from the lamp (blue or black) will connect to the other two blacks.
Don't want to sound rude, but you have to put some effort into helping yourself.
You could start by clicking the "No it isn't".
Thanks for the help guys.
Barn-all-shed - apologies I didn't know it was a link. Thanks for the help :oops:
