So no point in summer.
see above, you'd use the heat to heat up water for household use.
The advantages of this system, is that in the summer, you turn it off? Or reverse the fan, to provide cooling to the whole house.
Reversing the fan generates cold air from where?
So it sucks and or blows walm air?
Where does this new magical element change temperature by just going thru a fan?
So pumping hot air into a room does nothing?
It certainly does not cool it.
Worked it out yet?
The theory of heat exchangers is generally that you get 4 times back the energy you put in
So you could only cool your house if you had wet washing to dry?
Could you not just open a window?
Phil you haven't a clue about water bylaws for preheating water or the need to get wras approval, the whole idea/setup is laughable.
