I need to drain down CH system but there is drain valve at lowest point.I would like to make a radiator tail using a short length of copper with sevice valve in-line and solder the copper to female part of rad valve.
1. will this work ?
2.is there a better method of achieving a drain-down point?
I ought to emphasise that this will be a temporary measure and I will use a more permanent solution later eg a radiator valve with integrated drain-off valve
1. will this work ?
