So, after a drain down and re-fill I worked on bleeding the system.
i bled the pump and switched on the heating. the pump appeared to be sticking in that it didn't come on immediatly. Now it seems to be siezed completely?
I can hear it make a light buzzing but it's not turning. you can hear it turn when you turn it with the bleed screw.
it's a BG branded myson mutlihead II, got a sticker inside the connection box that says 2001.
Is there anything a can try to get it going or should I just go straight for a replacement due to the age?
I loaned my multimeter so can't check it's getting power, but i'm pretty sure it is.
Cheers,
Cheers,
