cross sectional area
Can you fix my broken one.
yes. easily. It most likely is an installation fault tho!!
That's a typical response from a s**t engineer that works for a s**t boiler manufacturer.without evening asking what's actually wrong your straight in with installer error.
With that sort of attitude/response theres no wonder people stay away from the trashy products you push.
your not an engineer an nor am I
I done a four year apprenticeship an worked for bg for 7 years a boiler manufacture an now another energy company so trust me am not ****! as you put it. I simpley said I could fix it easily I could cause am well trained on that boiler. an I would be surprised if It was a boiler fault tbh
cheers
your not an engineer.
Erm,actually I am an engineer, my degree in mechanical engineering sees that I can use that title. :wink:
Boiler in question is hard fault forlow pressure,no leaks,no drips,boiler gauge showing between 1.5-2 bar,independent gauge cane at 1.3bar.
Let me guess it's a system fault.
faulty independent gauge?! must be. :wink:
just let me confirm my post wasn't a wind up so pls lets leave it at that
i apologize for asking now!
3 different companies worked for in less than 4years , that suggests sh#te worker.
But then again that is if you are not some regular posters alter ego who is into winding people up and your name would always grab attrention to start it
Basic maths from what you have put dopey you have been working 15 years so left in 96
4 year apprenticeship so that at takes you to sept 2000 as apprentciceships start in sept for college
7 Years Bg so that is Aug/sept 2007
3 years ideal Aug/sept 2010
Now with someone else its june 2011
So from june 2007 which is 4 years ago you have been employed by 3 companies. So that is 3 in less than 4 years or do you want to change what you have previously put.
I bet you think it takes 12 years to have 3 world cups seeing as they are every 4 years
stalker :lol: that dosnt mean am a bad worker tho does it? how does it?
I simply go where the money is at that time as when ever i go for a job i get it, because i **** the assessments
I have no loyalty to a company because they would drop you like stone, an if you think bg wouldn't your a fool son
**** me,how big headed are you.most people could walk an BG/eom/npower assessment, there not difficult(how you passed the vent questions could be a little bit concerning).Does that make you brilliant at your job,not specially,come and play with real gas lines if your that clever.
As for chasing the money,good luck as soon as you balls up,which you will,your P45 will be already written.
Stalker NA but if your going to lie and make things up the one thing you need is a good memory , guess its hard with all the user names to remember what you put under which one :wink:
I dont work for Bg so could not drop me like a stone , my boss is a really good guy to work for part time hours full time wage :wink:
Not really just 85% of gas fitters are ****. i disagree with most people could walk an assessment, cause if they could there would't be so many of you self employed would there! you would be hard pushed self employed to get what i get for the hours i do. honestly.
40k direct without overtime 4 day week for 6 months. dont forget i done a bit self employed an its hard if you want to earn decent cash, unless you work for peanuts then again monkeys do
