Can you fix my broken one.
yes. easily. It most likely is an installation fault tho!!
Yes, the water in a 20 year old system was a little off colour and this caused the PCB to fail!!!
your not an engineer an nor am ICan you fix my broken one.
That's a typical response from a s**t engineer that works for a s**t boiler manufacturer.without evening asking what's actually wrong your straight in with installer error.
With that sort of attitude/response theres no wonder people stay away from the trashy products you push.
your not an engineer.Can you fix my broken one.
Erm,actually I am an engineer, my degree in mechanical engineering sees that I can use that title.![]()
**** me,how big headed are you.most people could walk an BG/eom/npower assessment, there not difficult(how you passed the vent questions could be a little bit concerning).Does that make you brilliant at your job,not specially,come and play with real gas lines if your that clever.
As for chasing the money,good luck as soon as you balls up,which you will,your P45 will be already written.
