Dimmer switches
As long as it will fit it should be fine.
What he said. You might be able to install the transformer in the ceiling void if the original cables on the low voltage side reach. To be belt and braces sure of compatibility I suggest using the varilight remote touch dimmers.
Also, the transformers are cheaper and in stock here http://www.thelightingsuperstore.co.uk/product.asp?productid=12037 and the dimmers here http://www.thelightingsuperstore.co.uk/category.asp?catcode=80
Hope this helps.
Matt
