Either it's DO NOT PULL THE CUT-OUT (DNOs - is it really law?) or DO NOT WORK LIVE (EAWR it is really law).
The EAWR talks about suitable training and qualification. If you are not trained to pull the main fuse and deal with anything you may find you can't do it.
As soon as that fuse is pulled you expose a live terminal (there is NO guarantee there is any form of shrouding) to make it safe with shrouding is classed as working live - and you can't do that!
Can you identify a cantark cut-out, that no one can withdraw fuses from under any circumstances (or one or two other types that are dangerous to withdraw fuses from or need special pecautions)
If you do pull the fuse and it goes wrong do you have access to a direct line to suitable people to assist you?
What is the approved method of checking polarity?
Do you have the appropriate safety equipment (in my DNO the coveralls cost about £150, never mind the gloves, the visor (there are a few approved types, do you know what they are?)
I sit and read advice on here from qualified electricians to DIYers about how to do it correctly, what they cannot do, what tests they need to do.
Yet I see qualified electricians still suggesting they can withdraw fuses or questioning why they cannot - sorry if you won't accept what you cannot do, why do you think you can advise others?
At the end of the day the main fuse belongs to the DNO, unless you have specific permission (authorisation) from DNOs what makes anyone think they are allowed to interfere with that equipment?
A particularly high risk on an overhead TT supply where the neutral is not tied to earth at the service intake and the phase and neutral might have got reversed on their way from the pole.
Interesting point, our isolation rules do not require we isolate the neutral in any circumstances.
The polarity question I mentioned above!
