has anyone used excel consumer units. What is the build quality like? How are they to install? do they compare to usual brands. MK, Wylex etc. Any information appreciated. Thanks.
Given that the 'earlier topic' was started just 3 minutes before this one, I presume it was merely a case of a duplicate post (which, as we all know, is so easy to perpetrate on this forum) of which the OP was probably not even aware.exactly the same.
This model must be the type most suitable for most old houses yet it can't protect properly.
My advice must be DON'T BUY.
...or he connected the neutrals of the 'protected' circuits to the wrong neutral bar.im not sure what you mean, you mean there is no neutral bar for the RCD? or the non-protected bar is joined to the RCD bar?
Quite so - and, in any event, what was anyone doing fitting a single-RCD 'split load' CU in 2013? One also wonders what he means by "With daylight running out I connected all the circuits to the unprotected strip". I presume this work wasn't notified!surely checking the layout configuration of the CU should have been done before even fixing it to the wall? And certainly tightening factory connections should have been done before energising anything
No - but it is his fault that he went ahead and did something despite having nowhere near enough competence.Its not their fault that you do not seem to know how to
a) test an installation prior to changing a consumer unit
and/or
b) understand how to configure a dual/split load consumer unit
You know full well that the only pointers which any responsible person should give areIf you are still having trouble, just post a couple of good quality pictures of your installation and we'll give you some pointers.
Also, let us know what the IR test results were on each circuit.
That is quite normal, a lot of boards require the live busbar to be cut, to requirements of the load split of the installationThe Excel kit came with a single copper line bus.
As above, this is normalIf you need a mix of RCD-protected/unprotected circuits you have to cut this.
Comes with knowing what you are doing, CU should be fitted by those with skill, knowledge and ability to do so, and those people with this, would be aware of the methods required to do perform this task!was nothing in the kit that said anything about this. Cutting the bus (and making sure there is a decent space between the ends) is the solution I have found.
You are entitled to that, but not a very informed opinion judging by your displayed knowledge.The original Question was whether Excel units were OK and I posted my opinion.
did all the other tests conform and were they documented?The man from Southern Electric tested my wiring and it passed the insulation test.
I would consider the leaflet contained within the packaging, recommending that the unit was fitted in compliance to BS7671 and by a qualified electrician would be the one the buyers come installer, should be really be taking notice of!As supplied, this unit was not fit for purpose because it did not contain important information. That's my warning to would be buyers.
