Thanks in advance for any advice given.
My kitchen lights stopped working....
Basically I have 4x 240v Halogen down lights (all with 20w lamps) in my kitchen, also part of the same circuit is 2 mains pendant fittings. These operate from a dimmer switch. These lights I believe lead on to the external wall fan, so all part of the same circuit. The kitchen lights are part of an 3 year old home extension so there not connected with the older part of the house. (Each of the mains down lights was a good quality fitting, not cheap.)
Ive visually checked the connections behind the dimmer switch and the fan switch and all appear to be connected fine. Ive also changed all the lamps for new ones. The CU had tripped out so thats back on as well. Thats about the extent of my knowledge on what I can check.
Any further ideas on what to check next or what could be causing the problem? Again, thanks in advance for any advice.
Cheers.
Cheers.
