cadet - is it?
My first reaction in such circmstances is to say exactly that - but when I start thinking, I wonder how much it stands up to much scruitiny - since the lighting circuit wiring is, by definition, already adequately protected by its MCB. The worst that could happen if a large load were plugged into the socket therefore should be operation of the MCB, taking the lights out - and I don't think one can actually be too sure that a 3A fuse would always operate before the MCB, anyway. Suitable labelling of the socket is probably the best 'protection' against large loads being plugged in.Big danger about having a socket on a lighting circuit is the fact that a normal socket could have anything up to 13 amp plugged in. It's best to have fuse spur between the lighting and socket to restrict the load to 3 amp to cover such stupidity.
Whereupon the MCB trips, the lights stop working, the penny drops and the heater is not plugged in there again.I can see a nice 2 bar heater being plugged into this![]()
Yes, that's one solution, and a solution I've frequently used. However (unless used in conjunction with an FCU, which would rather defeat the point!) it does leave the cable of whatever is plugged into protected only by the circuit's OPD, which could theoretically be inadequate protection with smaller cables (e.g. 0.5mm²).
Interesting - I have wondered why such things never emerged. Do they use standard BS1362 fuses (I wonder if they could be made to fit!)? Can you indicate any source?Some of the newer 5 amp plugs do have fuses fitted.
