is it ok to run a mains cable alongside a carpet gripper?
Run your hand along the carpet gripper and you will answer your own question![]()
It is a bad idear as if the cable moves and gets caught in the spikes, it will make a big bang and you will need the carpet re streching to get it to fit properly again.
You can get skirting board for cable to run in.
What if the cable is clipped?
As in clipped to the floorboards next to the carpet strips? No - You don't want cable running along floors under carpets where it will be liable to be damaged.
Then run it in horizontally the wall.
The house has recently been refurbished to a high spec, i don't think 2.5mm t&t would go down well.
yet sockets were not fitted where they were needed? Was it actually rewired?The house has recently been refurbished to a high spec
This may be an obvious question: What is the floor made of? If its wood then lift the floor and run the cable underneath.
The room is on the ground floor and the floor is of some solid material, not concrete but hard.
