just been told if I convert a double socket into two singles I can then feed a fused spur off each socket... can anyone confirm that is possible and more so OK for part P regulations etc...
As designer do you believe that that load distribution would meet the deemed to satisfy requirements in 433.1.5, and Appendix 15 1(i)?can anyone confirm that is possible and more so OK for part P regulations etc...
yes its related to my other post but didnt want to confuse the issue as my initial post as before talking to the guy that doing the work and is registed etc... Thanks.
then he should be competent to do the works.registed etc...
If the designer didn't believe that, then none of the solutions so far suggested would be satisfactory, since all involve taking two spurs off very close points on the ring. In that situation, it would presumably be necessary to find a way of feeding one spur from a more distant point on the ring (probably impractical) or installing an additional final circuit.As designer do you believe that that load distribution would meet the deemed to satisfy requirements in 433.1.5, and Appendix 15 1(i)?can anyone confirm that is possible and more so OK for part P regulations etc...
I'm just very curious and checking what I'm being told is right... too many rouge traders/cowboy builder programmes.
Maybe - but in the context of this OP's questions (particularly the original thread) I presume you would do not regard the contractor's view of what should be done as acceptable, would you?Too many rouge customers, seeing a 25min show and thinking they know the relevant regsI'm just very curious and checking what I'm being told is right... too many rouge traders/cowboy builder programmes.![]()
And chalking this up as another example of a ring final being an unsuitable design.In that situation, it would presumably be necessary to find a way of feeding one spur from a more distant point on the ring (probably impractical) or installing an additional final circuit.
I realised that, but thought that there might be some confusion in the context of this thread - since the 'professional' advice apparently received by the OP is, indeed, on this occasion, suspect.I was making a general comment.
Alarm said:Too many rouge customers
................................Was everyone wearing red ?
