"Electrical equipment shall be installed in accordance with the instructions provided by the manufacturer of the equipment."
Are you disputing that?
And recently
Your red should be permanently live and go to wavy line/arrow terminal and black to L2.
From the varilight website.
Remove your old switch and copy the wiring configuration for the dimmerswitch. The wires from your old switch
can be connected either way round to the "C" and "L1" terminals of the dimmerswitch.
OR
In 1-way lighting circuits the light(s) are controlled by one switch. This dimmer should replace that switch. The live wire must be connected to the
terminal marked "Live↓" and the "load" wire to the terminal marked " ".
GUARANTEE
Important: In case of any defect return the dimmer to our service department. This guarantee is in addition to and not in derogation of the statutory
rights of the purchaser and is offered so that you may have the benefit of our technical facilities. Should any defect occur in this unit within 12 months
of its purchase we will replace or repair the defective unit free of charge provided that:-
a) The unit has been correctly fitted according to the instructions
