Hi there,
I was thinking of installing this cooker and hob
BOSCH HBN331E0B Built-in Electric Single Oven - Brushed Steel + PKE611E Built-in Ceramic Hob - Black from curry's
My question is ..The manual for installation of the oven states it has to be hard wired and not to use a 13amp plug even though it is rated at 2.3kw. I think the hob is rated at 6.3kw .
I have a cooker control switch with red isolater switch and plug socket combined .Then i have the connection unit behind my exsisting stand along electric cooker .The consumer unit that protects the cooker circuit is protected with a 32amp fuse.
Could i use a click 45a easyfit dual appliance outlet plate and connect 2.5mm twin and earth from dual plate to the oven and connect 4mm twinn and earth from dual plate to Hob ?? I have added diversity when calculating as everything would not be on at the same time.
Any advice appreciated thanks..
