Hello, I am wondering is it ok to wire a socket from inside an existing fuse spur that powers my intruder alarm, Would only be running a router of it & possibly a lamp, Was going to wire in consumer unit but getting a bit tight on space. Thanks in advance
probably will not do that then, Is this ok to do.
Wire from existing FCU mains side to a new 13amp FCU then connect load side from new FCU to the socket
For "a router [I presume a broadband one, not a workshop tool!] and maybe a lamp" (plus the existing alarm) I would have thought that 3A would be sufficient, wouldn't it. I agree that '13A' sockets with upstream 3A fuses do not sound that nice - but they are not unsafe, and I suspect the reason the OP needs 'a 13A socket' is that the router comes with a wallwart.
Not strictly permitted according to BS7671, but from the practical point of view simply extending from the supply side of the existing FCU to a single 13A socket is no worse (and in fact could be considered "better") than putting a double socket on an unfused spur, which is permitted.
I would reply that you may do that if you wish but I don't think it sensible to advise DIYers because it won't be long until someone plugs in the vacuum cleaner and sets off his burglar alarm.
There's usually a battery backup in the alarm panel. But why would plugging a vacuum cleaner into the socket be likely to result in the power being cut? Or more specifically, why do you think it any more likely to happen with this arrangement than with any one of several others?
Ah, no. I meant with the socket wired directly to the spur:
