Hi.
I am going to be building my own property next year and have plans to start my own new build construction company after my own build has been completed.
The main requirement that I need is for the property to be as energy efficient as possible.
Regulations are changing frequently and as energy costs rise, this is going to be an ongoing issue with insulation sizes.
The first concern is insulation. A friend has recently built a property for himself and he has more than doubled the insulation requirements that was needed. Roughly 75% of a properties heat loss is through the floor, walls and roof and this is his reasoning for overcompensating in these areas. The extra cost from this alone will be recovered in 3/5 years compared to today's homes.
However he has also gone further by installing a GSHP, solar panels, fibreglass windows and an electric heat pump among other things.
He has been researching spray foam insulation and has found that it is superior to rigid insulation as it has similar thermal properties, but it can be sprayed into areas you could not normally reach. It also creates a much better air seal.
What I would first like to know is peoples experience with spray insulation, good or bad. Also if there are any other ideas of creating a more efficient home.
Many thanks.
Many thanks.
