Hiding cable
5 Jan 2003
Essex
I understand you cannot hide cable, eg 2.5mm T&E behind the skirting board but is it okay to put it on front of the skirting board in a trunking? I'm confused as you can buy a mould trunking that goes on top of the skirting board but isn't that a hidden danger? Can't see what's the difference if it's behind or hidden in front :? If not, then I can go another route but it's a lot more work
If it is in trunking you can put it in front of or on top of the skirting board. But not behind it!
You can see where the cable is when in trunking so you can put wherever you like - diagonally across a wall, if you must.
Things only get tricky when the cable is concealed.
The difference is if it's behind the skirting board you cannot see it, if it's in front and made to blend in you can still see it.
If it is in trunking you can put it in front of or on top of the skirting board. But not behind it! You can see where the cable is when in trunking so you can put wherever you like - diagonally across a wall, if you must. Things only get tricky when the cable is concealed.
Reg-wise, yes. In the real world, it can also get tricky if the trunking is aesthetically so 'good' that it may effectively 'conceal' the existance of the cables, by looking to some people as a plastic skirting (or plastic part of skirting). I know of a case in which someone drilled into one (to attach a phone socket or somesuch), not realising that it was cable trunking!
Kind Regards, John.
Use D line quarter round trunking. fit it where your skirting meets the floor and you'll hardly notice it at all.
Kind Regards, John.
This is why I'm surprised it's acceptable!
I'm wondering if it's possible to put a metal conduit inside the trunking? Not sure what's available
Now you are being silly.
Why not just have a length of thick black steel armoured cable running around the floor of your room. That would look so smart. But just think how much safer it would be.
Trunking is a perfectly acceptable method of cable installation. Some concrete construction flats have even beed rewired in the stuff. Just get on with it, any further discussion is pointless.
Masona has a point.
In theory it may be in trunking, but to all intents and purposes, in real life if you have an unnoticeable moulding atop the skirting, particularly if you paint them both, you have a situation no different from a cable behind the skirting.
Masona has a point.
Tap it with a knuckle. Anyone who drills straight into something without knowing what it is is dumb enough to drill into a safe zone, too.
Tap a thin bit of skirting loosely attached to a wall in a place where there's empty air behind it.
I've told you of the case I saw. The perpetrator knew that it was hollow plastic, but thought it was plastic skirting - so he drilled (very small) pilot holes into it for self-tappings screws (I think to attach a telephone socket) - and hit something other than plastic :-)
Kind Regards, John.
Kind Regards, John.
Then look for the seam or see if there's some actual wooden skirting under it. He'd probably drill into dado trunking thinking the sockets were just mounted on it. Common sense goes a long way.
Never heard of natural selection? This is how it works.
