Hi, I have a Bosch SGS43C12GB/08 dishwasher, and the issue we are having is that firstly it would not get past filling and then draining that water away - it just will sit there draining for as long as you leave it on. But I have also noticed that during this first cycle the water is cold, but to be honest we have never opened the door during the first cycle to know if it is meant to be cold or not - I do know that it is cold fill, so am unsure.
So far I have had the bottom off and checked the pump and the drain pipe as initially thought it was a blockage. I have also checked the pcb, but cannot see any burnt components or solder. I just took right hand side off as well and then disconnected the red wire off of one side of the heater unit, and measured 23ohms across it - so can I assume then that the heater is ok?
I have just had another thought, which takes me back to my original thoughts of there being a blockage somewhere - just after Christmas I was cleaning the filter out, and I noticed that a piece of glass (not sure where it had come from) was sat in the bottom of the filter - could there be more glass stuck somewhere? As said previously I have checked the pump, and made sure the propellers move freely.
