- Joined
- 27 Jan 2008
- Messages
- 28,955
- Reaction score
- 3,541
- Location
- Country
If today we got line and earth swapped then touching the live part and true earth would open the RCD so although the person would get a shock it would auto disconnect within 40ms so unlikely to cause death. Today all sockets under 20A must have RCD protection (with some special exceptions) and also buried cables have to in the main be RCD protected. Hence why I say today this could not happen.Ericmark,
"Of course we have not been given the exact dates and it was just as the new rules BS7671:2008 came into being and because of the changes in 2008 the same situation could not be repeated."
Could you explain this a bit further please?
An interesting (but sad) thread with some very interesting views.
Perhaps if we all used a simpler tester and a pulg in RCD adaptor before using a socket it might reduce risk a bit
Reading the reports it would seem it was the lack of an asbuilt plan which resulted in a human error being missed jurying the inspection and testing procedure.
Although some one clearly connected up a socket incorrectly we have to except that from time to time there will be human error but in this case there were two failures.
1) The mistake
2) Lack of asbuilt plans so tester missed the socket.
In the main accidents are caused by multi actions which means the courts often have to divide the blame between more than one individual. In this case clearly the guy who made the mistake in the wiring must take the majority of the blame but also who ever was responsible for ensuring the asbuilt plans were submitted and passed to the guy doing the inspection and testing must also take some on the blame.
As to the guy doing inspection and testing much would depend on the position of the socket. If it was an extra provided because the house was being used as a show house then one can't really blame him for missing it when hidden behind a filling cabinet. However if it was in a position where one would expect to find a socket i.e. the same location as sockets were found in other houses in the estate then clearly he must also take some of the blame.
Coming from a commercial back ground I was always surprised at the lack of as-built plans for domestic premises. And even where plans were drawn up it seems common for these to be included in the buyer pack but not issued to guys doing inspection and testing.
