Not needed unless there are new cables concealed in a wall, or the maker specifies one (unlikely with a fan).
If the lights are loop in it wont......
Wont switch the fan on and off when the lights go on or off as you could have a permanent supply to the fan.
sorrry just noticed timer which obviously would require the permanent live!!
Nice.The Fan i'm going to use is the same as i have in my bathroom - and i'm going to give this to the electrician to install. It's a very quiet fan and not really noticeable at all - especially with all the noise in my house anyway.
The ones who said what you wanted to hear?Thanks for some good adice AT LAST from some posts that seem to know what they are talking about,
Trusting soul aren't you?if my electrician says i need an RCBO to replace my MCB, then i will say i do not - even though the work is in a kitchen and cables not buried in the wall.
As above.I'm only using surface trunking as i do'nt want my celing damaged.
Are you sure that this fan will meet the Building Regulation requirements Part F for a kitchen. Its 30 l/s by the hob and 60 l/s elsewhere - quite a few bathroom fans run at 15 l/s.The Fan i'm going to use is the same as i have in my bathroom
hmm, trunking across the ceiling and down the wall. Lovely![]()
Forgive me as I must have misunderstood this post. I was under the impression that you were saying that there was no way of letting the fan work off the light switch when wired into the ceiling rose.
I still can't interpret what what you mean if not what I have suggested!If the lights are loop in it wont......
Certainly.Also EFLImpudance I think its up to the op which method is chosen with regards to his/her personal choice as long as the install is safe and conforms to BS7671.
I agree. Nor would I.I certainly would not knock a job back if the customer wanted surface mount with no RCD if that is what they wanted due to cost
You have misunderstood my reasons for declining.
