cylinder with no drain cock
15 Apr 2005
Yorkshire
How does one drain a cylinder without a drain cock? My cylinder doesnt have one. I was planning to have it drained down ready for the gas engineer in a weeks time, but fear it may not be that simple . . .
I had thought about maybe cutting off the cold infill above the cylinder top, then attaching a hose to this and bending the pipe (or the cylinder with pipe attached) over to slowly drain it off.
Or even syphoning off the water - stick a hose in the top, take it downstairs and suck!
Of course both these involve far more than my remit of "turning off the mains and opening everything" so I wont be attempting it, but how would you do it?
I rarely use the drain off if the cylinder is going to be replaced or done away with. I shut the water off and either syphon out through the outlet or, if this is badly scaled, smack a hole in the top with an old chisel. You get a bit of spillage but a couple of strategically placed old towels saves any mess. The trick to make sure you get right to the bottom without the end getting blocked is to use a length of 15 copper with an elbow on the bottom. Be wary when sucking to start the syphonic action as you normally get a gob full of green water. It also come out at one hell of a rate so be careful where you're draining out to.
Is there really that much sediment in the bottom of a cylinder? For DHW?
:P I got softened water dude .
 8)
opps - that picture was bigger than i though :lol: :lol: :lol:
