You don't need to open the cover.
I would never advise a diyer to go opening an old wylex.
Even with the main switch off there is a big live lump of brass 3mm away from a large neutral lump. It is just too easy for things to go very wrong.
Why not turn off the main switch, cut the main earth and terminate both ends into a new earth block along with the new bonding cable.
Without a doubt, the best suggestion yet.
Can't quite tell, but is that a pipe clamp fitted to the incoming service sheath? If so, give your DNO a call. They should come out to modify/improve it.
Probably at a cost as it's not sweated on.
What, even better than my suggestion posted some 9 hours prior to RF's?
I've known it to be done FOC in the past
