H
holmslaw
I have seen above. You still haven't done it.Please show where I claimed you had used actual words which you had not.
see above
OK, fine - in that case what I wrote was about you, not about what you wrote.My comment was about the poster not the post, but you know that don't you.
I haven't made any, and until I can decide whether you are behaving like a complete **** just to disrupt things or if you really are simply ******* thick I'm not going to respond to any more of your tedious whining.So are you going to apologise for misleading people by making false allegations about me.
Am I?Why are you swearing again?
You've missed virtually nothing of relevance to your project - only 'playtime'Blimey guys you've been busy.
All looks fine to me - and, yes, you can use any size of fuse in that module.I'm now thinking I could do it all off the lighting circuit in a three module grid: .....
Quick question: this is shown as a 13A fuse module. Presumably this is also ok for housing a 3A fuse as I need for the fan. ....The wiring setup would just be this:
Fine. Even 1mm² would have done.I've also heeded advice and bought some 1.5sqmm T&E cable instead of the 2.5sqmm T&E I had left over from ring mains. And a short bit of triple-core for the fan with its permanent and switched live.
I should have added that I'm assuming that your mirror demister has low power requirements and therefore will be OK run off the 3A fused supply along with the fan.The wiring setup would just be this:
