having removed a very old light fitting , to replace with new chrome 1 , I have now coming down from the void in ceiling 2 wires , which are identical colour ( grey) How do i go about wiring new fitting ?
no it won't.That is normal. One will be + and the other -
I think you will find that bethjo and royboywales are associated, they coincidently joined the the forum one hour apart, and then started this nonsense thread.
Unless he lives in a caravan or something that runs off a battery, his electrical supply will be A.C.
When it comes to a light bulb, it makes no diference which way the current flows. Fact
You haven't wired any ES bulbs then - or have you just been lucky?When it comes to a light bulb, it makes no diference which way the current flows. Fact
My humblest apologies,although I have wire countless fittings that they are screwed into though![]()
So it makes no difference which way you wire a screw in light fitting then?When it comes to a light bulb, it makes no diference which way the current flows. Fact
Learn something new each and every day.
