removing one of my lights
5 Mar 2012
I currently have two lights in my living room controlled by a 3 switch (2 for the living room lights and 1 for the landing lights) I want to remove one of the living room lights and replace the 3 switch with a 2 switch... can anyone help please.
Photo please, of the back of the 3 gang switch
You'll need to clearly identify which switch does what.
Can't help otherwise.
PS Turn OFF the POWER BEFORE removing the switch
Or
Describe what the wiring is at the light you wish to remove.
And the wiring at the 3 gang switch. If there are any separate bunches of wires in separate connector blocks, describe this too.
the light you want to remove will either have a permanent Live and Neutral into it from another room and then a Permanent Live and Neutral to the next light in the living room with a switch live and Permanent live down to the switch or a Permanent live and Neutral from the first light and then a Permanent Live and Neutral to another room again with a switch live and permanent live down to the switch...
the fact this light i controlled by it own switch makes this trickier for you...
That is an AMAZING insight. Have you been to his house then, or do you have some magic powers?
This may not be a loop in at light system. It could be loop at the switch, or there could be one of those big brown junction boxes under the landing floor.
Lets wait and see what there really is, the answer will be different for each.
Yes to both....
Yes, the Wiki can - the answers are here:
http://www.diynot.com/wiki/electrics:lighting
Once you understand how lighting circuits work, you'll be able to see how yours works, how your switch is wired and what it's doing, and you'll know what to do to make the changes you require.
You shouldn't do the work until you do understand all that - just following electricity-by-numbers instructions without truly understanding what you are doing and why is a very bad idea.
