Hi Folks ,
I am about to start work on constructing a two tier pond in my garden .
When I fit my pump and filter , I`m thinking I`ll have to run a hose from one level to the other . Is it common practice to cut holes in the liner , so as to run the pipe under the surface and hide it . If so , do I need to buy some sort of kit to make sure the seal is water-tight . I contacted a pump supplier , and he said this wouldnt be supplied with the pump .
Thanks , Colin .
Thanks , Colin .
